HELP! Reset Temperature Values After Button Active for 3s!
Help!
Hello, I have recently started using LabVIEW at University, I am a complete novice.
I am required to reset the the minimum and maximum temperature values when the Celsius to Fahrenheit button is activated for 3 seconds. I have been playing around with Timer VI's but i cant get it working, any advice would be much appreciated. Please see screenshot below.
Is anybody able to send me a screenshot of something to fix my problem?
(1,445 Views)
Hi MBlair,
No screenshot, but some pseudocode:
IF button AND NOT(prev_button)  % detect rising edge
  start_time = current_time
ENDIF
IF NOT(button) and prev_button  % detect falling edge
  duration = current_time - start_time
  IF duration >= 3s THEN
    reset min/max values
  ENDIF
ENDIF
prev_button = button            % set prev_button for next iteration
See how far you get: you need just shift registers (for prev_button and start_time) and case structures (for IF-ENDIF)…
Suggestion: for a LabVIEW beginner I recommend to use shift registers instead of feedback node. IMHO they are easier to understand in term of DATAFLOW…
(1,439 Views)
First you need to explain what "reset" means. Reset to what? (current temperature, some defaults, etc.)
There is no need to have the temperature in a shift register if you also have the feedback nodes. All you need is shift registers that contain max and min. They need to be initialized with -inf and +inf, respectively that will get reset, when your button is pressed for >3 seconds. For this to work correctly, you also need to change the mechanical action (e.g. to "switch until released")
(1,408 Views)
See if this can give you some ideas.
other notes:
  • Use the chart digital display for the numeric indicators. Fewer terminals!
  • Don't label an indicator "degrees celsius" unless that's what it always displays.
  • As mentioned, use the correct mechanical actions for booleans.
  • You can remove the code going to indicators in (). They are just for demonstration
  • The elapsed time express VI is overkill to get current time for display
  • Please don no maximize the diagram window.
  • A meter is typically used as an indicator and a slide as a control. Now sure why you use them in opposite fashion.
  • A toggle switch is not an intuitive stop button
  • Use arrays and clusters to simplify the code
  • etc.
(1,385 Views)
