HELP HAVE YOU SAMPLES IN ORDER TO USE I²C BUS
I need to send and read data in an EEPROM WHITH an I²C BUS.
I'd like to know how configure this bus whith Labview.
THANKS..
(2,870 Views)
Cal-Bay Systems has an I2C board that comes with LabVIEW Drivers.
http://calbay.com/I2C_driver.htm
Good luck,
-Jim
(2,870 Views)
I2C Chip's PC-2-I2C usb/serial adaptor (http://www.i2cchip.com) just
has a simple serial ASCII interface that is like the Philips
documentation.
Most any language can use a serial/usb port.
If not you can use Realterm, which has an AciveX interface so that any
windows program can talk to the serial port.
(http://realterm.sourceforge.net)
eg to send the byte 0xF4 to a PCF8574 just send this string:
S 40 F4 P
If you didn't get it it means
[START] [Address 0x40, ie write to PCF8574] [data=0xF4] [STOP]
eg to read 1 byte from the same 8574
S 41 01 P
[START] [Address 0x41, ie read PCF8574] [Read 1 byte] [STOP]
This adaptor is really intended for making cheap, fast, isolated
instrumentation. Since you are using labview, it might be up your
alley.
BTW there are aslso programs to program eeproms from the commandline
floating about on the net.
regards
Simon
(2,870 Views)
