Guidance on using a Unit Test Framework
I have a HAL library with a bunch of classes and VI libraries that I use with Teststand. I have to develop code such that the entire HAL Project Library tests itself. The testing should cover functional correctness and regression testing. I looked up online found the following three frameworks available for unit testing. I am not sure what to work with?
NI Unit test framework
JKI VI tester
JKI Caraya
(2,390 Views)
All those options can be used to start that process, you will get the most documentation/support going with the first/NI option. Can confirm it has regression testing.
________/~~~~~~~~*********~~~~~~~~\________
Certified delinquent LabVIEW developer. Recertifying at next NI Days
(2,379 Views)
