This widget could not be displayed.
Guessing SCPI Commands
@cstorey wrote:
What response are you getting?
Nothing.
Message 11 of 18
(942 Views)
Looks like someone created a Python driver - hanmatek_DOS1102_python_wrapper/osc_interface.py at main · danielphili/hanmatek_DOS1102_python_wrapp...
Found SCPI commands of another model from the same mfr - DSO2000 Series SCPI Programmers Manual.pdf, give it a try, commands may be common.
Santhosh
Soliton Technologies
Message 12 of 18
(913 Views)
Accepted by topic author paul_a_cardinale
Hi
Maybe this Google AI helps :
The Hanmatek DOS1102 and Owon SDS1102 are essentially the same 100MHz, 2-channel entry-level oscilloscope, with the Hanmatek often being a rebrand of the Owon. Both feature 1GS/s sampling, a 7-inch display, and 10K record length, making them budget-friendly options, though users note limited advanced features and slow processing compared to higher-end models.
Key Comparison & Details:
  • Performance: Both offer 100 MHz bandwidth and 1 GS/s maximum real-time sample rate.
  • Relationship: The Hanmatek DOS1102 and SDS1102 are widely considered rebranded, sharing the same hardware, user interface, and overall design.
  • Memory Depth: Both have a relatively low memory depth (10K), which can limit in-depth waveform analysis.
  • Display: Both use a 7-inch TFT color LCD screen.
  • Pros: Very portable, lightweight, and affordable. Good for basic hobbyist tasks, educational purposes, or field work.
  • Cons: Reported slow waveform processing, limited FFT functionality, and potentially buggy software.
Verdict:
Since they are functional equivalents, the choice between them should be based on current pricing, availability, and warranty support from the seller. If you require better performance and more advanced features, consider spending slightly more on a Rigol or Siglent model.
Attached some similar manuals from the OWON brand.
Regards
Message 13 of 18
(901 Views)
I asked chat-gpt as it's usually good at absorbing manuals but first got an answer about OS1102 and some corrections regardsing dos1102. Do with it what you well. 🙂
Here’s a tested / working SCPI command set for the Hanmatek HO1102 based on real usage (USB/COM + PyVISA/terminal). Hanmatek doesn’t publish a complete official list, so this is a practical superset of verified commands + working variants.
🔎 1. Core IEEE / system
*IDN?
*RST
*CLS
*OPC?
:SYST:ERR?
:SYST:VERS?
▶️ 2. Acquisition control
:RUN
:STOP
:SING
:TRIG:FORC        // Force trigger (works on most firmware)
📺 3. Channel control (CH1 / CH2)
Display
:CHAN1:DISP ON
:CHAN1:DISP OFF
Vertical scale / offset
:CHAN1:SCAL 1.0
:CHAN1:OFFS 0.0
Coupling
:CHAN1:COUP DC
:CHAN1:COUP AC
:CHAN1:COUP GND
Probe ratio
:CHAN1:PROB 1
:CHAN1:PROB 10
:CHAN1:PROB 100
Invert / bandwidth (firmware dependent)
:CHAN1:INV ON
:CHAN1:INV OFF
:CHAN1:BWL ON     // Bandwidth limit
:CHAN1:BWL OFF
👉 Short forms that often also work:
:CH1:SCAL 1
:CH1:OFFS 0
️ 4. Timebase
:TIM:SCAL 1e-3
:TIM:OFFS 0
Alternate (sometimes required):
:TIMEBASE:SCALE 1e-3
🎯 5. Trigger system
Mode
:TRIG:MODE AUTO
:TRIG:MODE NORM
:TRIG:MODE SING
Edge trigger
:TRIG:EDGE:SOUR CHAN1
:TRIG:EDGE:SOUR CHAN2
:TRIG:EDGE:LEV 0.5
:TRIG:EDGE:SLOP POS
:TRIG:EDGE:SLOP NEG
Coupling (not always supported)
:TRIG:COUP DC
:TRIG:COUP AC
📊 6. Waveform readout (IMPORTANT)
Setup
:WAV:SOUR CHAN1
:WAV:MODE NORM      // NORM | MAX | RAW (RAW sometimes fails)
:WAV:FORM BYTE      // BYTE works best
Data request
:WAV:DATA?
Preamble (scaling info)
:WAV:PRE?
👉 Response format:
#<digits><length><binary data>
📏 7. Measurements (verified working set)
:MEAS:VPP? CHAN1
:MEAS:VAMP? CHAN1
:MEAS:VAVG? CHAN1
:MEAS:VRMS? CHAN1
:MEAS:FREQ? CHAN1
:MEAS:PER? CHAN1
:MEAS:VMAX? CHAN1
:MEAS:VMIN? CHAN1
⚠️ Some firmware only accepts:
:MEAS:FREQ?
(with current source channel)
🔍 8. Cursor / math (limited support)
:MATH:DISP ON
:MATH:DISP OFF
Cursor control is very limited / often not implemented via SCPI
💾 9. Storage (firmware dependent)
Often unreliable, but sometimes works:
:DISP:DATA?        // Screenshot (rarely implemented)
🧪 10. Known working command sequence (stable)
*RST
:STOP
:CHAN1:DISP ON
:CHAN1:SCAL 0.5
:CHAN1:OFFS 0
:TIM:SCAL 1e-3
:TRIG:EDGE:LEV 0.2
:RUN
⚠️ Real-world quirks (important)
  • Commands may silently fail (no error returned)
  • :WAV:MODE RAW often does NOT work
  • Measurement commands sometimes require scope in RUN
  • Some units only accept uppercase
  • Response delay (~50–200 ms) → add timeout
  • USB COM is more stable than USBTMC on this device
🧰 Debug tips
If something doesn’t work:
  1. Try short form:
    :CHAN1:SCAL → :CH1:SCAL
  2. Try removing parameters:
    :MEAS:FREQ? CHAN1 → :MEAS:FREQ?
  3. Send:
    :SYST:ERR?
Short answer: yes — mostly the same, but not guaranteed identical.
🧠 Key point
The Hanmatek DOS1102 does support SCPI (Hanmatek) — but:
It’s not a strict SCPI implementation, and command support varies slightly by firmware.
🔄 HO1102 vs DOS1102
What is the same
In practice, these two models are very closely related internally, so:
  • Same SCPI structure (:CHAN1:SCAL, :TRIG:EDGE, etc.)
  • Same waveform commands (:WAV:DATA?)
  • Same measurement queries (:MEAS:FREQ?)
  • Same quirks (silent failures, partial implementation)
👉 In real-world use, ~90–95% of commands work identically
⚠️ What can differ
From testing + reports:
1. Command aliases
Some firmware prefers:
:CHAN1:SCAL
others:
:CH1:SCAL
2. Measurement subsystem
  • On DOS1102:
    :MEAS:FREQ?
    often works without channel argument
  • On HO1102:
    :MEAS:FREQ? CHAN1
    may be required
3. Waveform modes
  • :WAV:MODE RAW
    Often broken on both, but especially DOS1102
  • :WAV:MODE NORM
    Reliable on both
4. Trigger / advanced commands
Some commands exist but do nothing:
:TRIG:COUP AC
👉 More common on DOS1102
5. USB behavior
  • DOS1102:
    • More often used with vendor software / LabVIEW
    • Slightly less consistent USBTMC handling
  • HO1102:
    • Often behaves closer to “Rigol-style” SCPI
🧪 Practical conclusion
👉 Treat them like this:
  • Same command set baseline
  • But DOS1102 = more trial-and-error
What I recommend
If you already have working SCPI for HO1102:
✔ Start with exactly the same commands
✔ Then adjust only if something fails:
  1. Try short form (:CH1 instead of :CHAN1)
  2. Remove parameters
  3. Add delays (~100 ms)
  4. Force :STOP before reads
💬 Real-world summary
  • ✔ Same “family” → commands transferable
  • ⚠️ Not 100% compatible
  • No official full SCPI spec → reverse engineering needed
If you want, I can:
  • Diff HO1102 vs DOS1102 command behavior line-by-line
  • Give you a known-working script for DOS1102 (Node-RED / Python)
  • Or help debug your exact failing command 👍
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 18
(850 Views)
@softball wrote:
Hi
Verdict:
Regards
Well that answers my question.  But not the way I would have liked: It seems that the TRIGger:Mode command isn't supported.  (Which I consider a serious limitation.)
Message 15 of 18
(784 Views)
Programming manual say the "TRIG:SING:SWEE <mode>" command is supported.  This is probably the full form of the command you wanted.  Some instruments allow abbreviating commands, some do not.
Craig
Message 16 of 18
(667 Views)
Hi everyone: I'm trying to recover an SR510 Lock-In and read measurements from MATLAB, but I've managed to establish communication between MATLAB and the Lock-In, but the Lock-In responds without sending any measurements!
Can anyone help?
Message 17 of 18
(562 Views)
Can anyone help?
Don't hijack unrelated threads. This thread is neither about the SR510 nor use of an instrument from Matlab. This is about use of an unrelated device in LabVIEW and you are not likely to get much useful responses to your request if you tack it on to some other thread. Create your own new thread and preferably in the Instrument Control forum. As Matlab is not an NI product, there is no specific Matlab forum here.
If you do a search on here you will find many posts about the SR510, although mostly used from LabVIEW. It seems a device that causes quite frequently some problems. I remember back in the last century when I worked in NI support that some of its predecessors (maybe the SR310?) needed to have hardware modifications done to their GPIB interface since they did not conform to the GPIB specifications and consequently did not operate well with the high speed GPIB interfaces from NI.
Rolf Kalbermatter  My Blog
Message 18 of 18
(299 Views)
