Guess what day it is geniuses!!! Random question Thursday!!!! Mr. Altenbach, the number 1 along with other geniuses, can you guys answer this ?
dis for u. c attached vi
i have answers fo my question
Message 11 of 16
(974 Views)
Accepted by topic author GRCK5000
This is the latest in your "Random question Thursday!!!" posts, one where you eventually posted your code, then your "solution" the following day.  About a decade ago, LabVIEW shipped with a "Generate Excel Report" example.  One of the Forum readers was not very satisfied with this Example, and generated a topic called "Revised "Generate Excel Report" Example" which extended and documented how to generate an Excel Report with Labeled Table, Tabular Data, and a plot of these Data.  If you search the Forum for the phrase "Revised Excel Example", you will probably find it -- though it is a decade-old Post, you might find it useful.
Message 12 of 16
(921 Views)
Thanks Bob. I'm about to check it out.
Message 13 of 16
(918 Views)
Thanks Bob for the reference. Great post and awesome code.
Message 14 of 16
(915 Views)
I respectfully ask you to no use my forum name in posts subjects, Don't post the same Vi multiple times in a row, and don't attach VIs that have the front panel maximized to the screen.
Please keep the subject short and concise! Don't constantly overuse exclamation marks!!!!!!!!!!
Compare:
  1. Guess what day it is geniuses!!! Random question Thursday!!!! Mr. Altenbach, the number 1 along with other geniuses, can you guys answer this ?
  2. Problem with excel report formatting.
Your subject (1) has absolutely no useful information about the question. Right?
Your question always circle about solving some ill-conceived convoluted problem, e.g. how do I get exactly some result while hanging upside down, tapping the head and rubbing the belly. A much better question would be to tell us what kind of data you have and ask what the best way would be to present and save it..
Yes, everybody should take this forum serious. This is a technical forum dealing with technical questions about LabVIEW, nothing else. If you want to do an offtopic discussion, there is the breakpoint. If you are looking for a social site, there are plenty of alternatives. Good luck! 😄
Over and out! 😄
Message 15 of 16
(888 Views)
I hear you Mr. Altenbach. I'll be trying to be more specific and give more detailed. Also, thank you sooooo much for the breakproint link. Yayyyy!!!!
Message 16 of 16
(877 Views)
