Group arrays then plot data
In the attached llb, I am attempting to group blocks of data to build arrays.
I take data over different conditions: Temperature, Test Conditions, and Frequencies.  For example, at room, I will test the Frequencies 168.036, 463, 478 and 493, 422.58, 435.43, 448.288 and 460.899 under the "Original" and "Tune1" test condition. I will then test at 60 degrees, 168.036, 463 and 478 under "Original" and "Tune1" test condition.  Then at -30 I will test 168.036 and 478 under "Original" and "Tune2" test conditions.  I wanted to then be able to select from the list boxes RM, Original and 168.036 and get that plot.  Then select, 60 and get that plot.  I am able to get the program to work partially, such that I am only able to have the RM, Original and any of the frequencies plotted.  However, when I go to select 60 from the Temp selection box, I do not get a plot.  Can you help me get the plots corresponding to the selection from the listboxes?  Thanks!
(3,327 Views)
Hello hiNI:
As far as I understand your issue, you want to plot one group of data (section of the array) at the time when you press the buttons on the front panel (cluster). I am correct with this interpretation?. You read all the information with the same format as the attachment (AT1A0201 Sweep Data - Copy)?.
(3,261 Views)
Yes, that is correct.
(3,253 Views)
Thanks for confirming the information. I believe that looking through your code looks like the management of the variable in the main Vi have a proper data flow. The only other Vi that may have an issue is the For_Loop.Vi. I did not check all the functionality of the code but I will focus on this Vi. As soon as a get a possible solution I will post my findings.
(3,225 Views)
