Grayed-out buttons during run-time
I tried with two button dialog, but parameters true and false are type of string, but I need to wire on prompt the ok button with the stop terminal, so there is type mismatch. It doesn't wotk with panel close? too. A prompt should appeat on the screen, but nothing happens. I also tried with Prompt user function, but I am not sure how to use it properly.
Message 21 of 23
(1,048 Views)
The output of the two button dialog is a boolean: TRUE if the left button (e.g. OK) has been pressed and FALSE if the right button (e.g. cancel) has been pressed.
Seems to be perfectly suitable for your purpose! 😄
(The input string determine what text should be displayed on the dialog and on the buttons.)
Please show us your code!
Message 22 of 23
(1,042 Views)
Oh yes...there is an error "connected to an undirected tunnel" when I try to wire the output of two button dialog. And, I am not sure what type ok an cancel should be: control,constant or indicator? I wouldn't say control, because it would be placed on a front panel, and I don't want this to happen. I need to make a classic "Are you sure you want to quit" prompt.
Message 23 of 23
(1,035 Views)
