Graphs
Has anyone got any ideas how to solve the following problem?
I have a report screen with several graphs on the screen. These graphs all
have the same X-axis data.
The Y-axis data can change the units are different etc. This means that the
graph plot area can move about within the control. The problem is only made
worse by having two scales on the Y Axis. I want to be able to position the
plot areas of the graphs so that the X-axis all aligned down the screen. Is
this possible?
If anyone has found a solution be it a different indicator or what ever I
would really like to hear from you.
Thanks in advance...
Duncan
(3,009 Views)
I think that the trick here is to turn off the autoscale function for the x-axis on each graph. You may have to setup a property node for each graph and change the X-scale, Range, Minimum, Maximum and Start. This should setup all of the x-scales to the same values.
Rob
(3,009 Views)
> this possible?
The knowledgebase has an article about this. You can place
enableAutoScales=FALSE
in the ini file.
Greg McKaskle
(3,009 Views)
