Graphing Output from a datafile
Hello sorry guys if this is a very simple question..
I have a VI that basically reads data from a text file .. I was hoping if I could convert this data into graphs using labview ?
(2,843 Views)
Hi evo...,
don't create new threads, use the edit function of the forum to change your messages or add attachments later on!
(2,832 Views)
It looks to me like the response you received on your other thread should lead you down the right path.  If you have further questions on this issue, follow up by issuing another post on the thread where a solution has been provided.
Jason W.
(2,820 Views)
