Graphic bug when creating stand alone application
The adjustment occurs because of the length of the text (the longest string in the scale markers), and the font size.
When a new scale string is calculated, if it won't fit in the available space, LabVIEW shrinks the plot area (if the auto-adjust option is ON) so as to show the scale.
It's possible you have a different default font on your machine, or you're using Large Fonts in the control panel, or any number of things like that.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 11 of 11
(358 Views)
