Graph
Hello Friends
                  I have one doubt in graph.In my application i have number of plots .I want to activate 5 plots in a single loop itself how to activate it
Jayavel
(4,014 Views)
Do you mean 5 plots in one graph?
(4,012 Views)
Not like that its having more than 25 plots.For an example only i told like that.
Jayavel
(4,010 Views)
You can build an array and plot in in a graph right?
(4,007 Views)
Hi
you need to have array of cluster.That way you can have multiple plots
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,003 Views)
2D array is all you need 🙂
This high-end code
Will produce this graph
If, on the other hand, you need a chart or some XY graph/chart, then you need something else 🙂
(3,978 Views)
