Graph
Ok. I saw your solution.
It might be best, but I do not have an exact sequence of the numbers of "Sart" (as your code creates). Your code creates a string (Sart 01, 02, etc. ..), but I have an array. How do I get to your result having an array?
Ps I was wrong before ... I meant graph, not chart.
So you think that tying the array x-scrollbar with graphic is impossible? You can not do that with a property node?
Message 31 of 46
(2,361 Views)
Nothing is impossible!
Message 32 of 46
(2,357 Views)
Mi fa piacere che pensi che nulla è impossibile.. 🙂
Però io non riesco a capire come fare...
Per favore, dimmi che riuscirai ad aiutarmi!!! 🙂
Message 33 of 46
(2,348 Views)
I'm glad you think that nothing is impossible .. 🙂
But I can not understand how to do ...
Please tell me you be able to help me! 🙂
Message 34 of 46
(2,347 Views)
Display the array scrollbar, then graph the data subset based on the index value and number of visible elements. You still did not attach your VI.
Message 35 of 46
(2,337 Views)
Hello Altenbach,
Could you explain more in detail how to do?
What do you mean when you say: "then graph the data subset based on the index value and number of visible elements"?
Thank you very much
Message 36 of 46
(2,312 Views)
Hi gmazza,
as said before: use property nodes!
Read the index value and number of elements shown from property nodes of the array indicator and use those to plot the visible values on your graph...
Message 37 of 46
(2,309 Views)
What do you mean when you say: "... and use those to plot the values visible on your graph ..."?
By using the property node pull out "Indexval." Which element of the property node of the graph I have to tie it?
Message 38 of 46
(2,302 Views)
Hi gmazza,
you have to wire it to ArraySubset.
A graph will show the data that is wired to it. You want to show the part of the array, that is visible in the array indicator. Hence: use ArraySubset to plot just the visible values...
Message 39 of 46
(2,299 Views)
Forgive me but I can not understand how to do ...
I am attaching my code so you can get a better idea ...
Message 40 of 46
(2,295 Views)
