Graph with String as Y-Axis
Need help on what graph to use for this:
Message 1 of 11
(51,098 Views)
I would use a 1D array of clusters where each element is a string and a slider.
You can also draw everything on a 2D picture (text, filled boxes, etc)
Message 2 of 11
(51,076 Views)
Thanks for the reply. If a slider will be used, how are you going to plot the FAIL?
Message 3 of 11
(51,042 Views)
Hi CmdrB,
A slider control can have more than just one slider. And there are several options for the fill color(s)…
Message 4 of 11
(51,034 Views)
Message 5 of 11
(51,021 Views)
I looked at your graph, and thought "How would I make a plot with a horizontal bar, the first 90% Green, the next 8% Red, and the last 2% Gray?", and came up with what I was going to suggest here as a possibility.  But when I clicked "Reply", and re-read the Title of the Post, I asked myself "What did @cmdrb mean by Graph with String as Y-Axis?".  That's when I paid attention to the Y tick labels "Op-01" ...  Oops, I just figured out how to do that, as well (maybe) ...
So let me forget about labeling the Y Axis for the moment, and talk about how to make a horizontal plot that goes from 0 to 100, with G% colored Green, R% colored Red, and the remaining 100-G-R% colored Gray.  Let's place this line at height H.  Plot three 2-point lines:
((0, H), (G, H)), ((G, H), (G+R, H)), ((G+R, H), (100, H)).  Color the first line Green, the second Red, the third Gray.  You can also increase the thickness of the lines, but to get as thick a bar as you show on your diagram, you'd probably need to plot several identical lines, varying the Y value by about .05 each time, as the thickest line (5) appears to be about 0.05 units high when plotted.  And trust me, unless you've done a whole lot of LabVIEW XY Plotting, making such a graph is not a lot of fun.
Here's what I got for my effort:
 I "colored" the three sub-plots "by hand" from the Graph Properties page, and also adjusted the Line thickness to the maximum.  I'm attaching a Snippet (saved as LabVIEW 2021) if you want to look at the code -- not so difficult, but I've not done much XY plotting, and figuring it out from the Help was, shall we say, not a big help (thank goodness for Examples).
Message 6 of 11
(51,017 Views)
Yes, I think the main(?) issue was that they wanted strings as Y axis markers. (QUOTE: "Graph with String as Y-Axis")
This idea would have helped!
But xy graphs also have horizontal bar plots, no need to jump through flaming hoops!
Message 7 of 11
(51,001 Views)
Here's how this could look like:
Message 8 of 11
(50,994 Views)
And here's how you could add text using the plotImages Overlay
(quick draft. could easily be tuned to the actual size and marker positions)
Of course at one point it would probably be easier to just use a 2D image for everything....
Message 9 of 11
(50,987 Views)
@Altenbach, you never cease to amaze us!
Message 10 of 11
(50,983 Views)
