05-26-2010 02:49 AM
Bonjour,
Je cherche un moyen d'afficher, sur un graph, du texte en lieu et place des valeurs de l'echelle des abscisses.
Si quelqu'un à la solution je suis preneur,
Merci
Nicolas
05-26-2010 04:17 AM
Sorry for French language in this discussion, I thought the post in the French forum !
I'm looking for a way to display on a graph some text instead of the values of the scale of x-axis.
Thank your for your solution
Best regard
Nicolas
05-28-2010 02:16 AM
You can't do it directly, you have to use labels. Have a look at this forum post.
I hope this will help.
Charlotte F. | CLAD
National Instruments France
05-28-2010 03:07 AM
Hi, Thank for your respond
I have use this way, but there is more complication when using zoom and pan graph.
So code programming must take more time.
I presume a xcontrol or object must be better, any body have develop this ?
Objet hierarchie capabilities can use with more facilities graph controls propertys and methods.
Nicolas
