Graph of the function
Hello! I also need help, I can't plot the function sqrt(7x)+2, if someone can help me, please. I want to plot something like this
(1,746 Views)
What is stopping you that you 'can't plot' that function? Have you tried something?
(1,741 Views)
First, you need a ramp of x values in a suitable range, then apply the function. After that, use an xy graph to display the data. This solution is independent of any specific programming language. (Be aware that negative x are not allowed unless you use a complex datatype for x)
Since you posted in the LabVIEW forum, we can probably assume that you want to use LabVIEW. What have you tried? Where did you get stuck? Do you have problem with the math? It's implementation in LabVIEW? Displaying the data? Something else?
(1,717 Views)
Here you have, but i dont know why its not correct.
(1,699 Views)
Hi MSF,
What's the point of this exp(x) function?
(1,690 Views)
First off, you have added an additional step that is not in your listed function.
If all of these math functions were within the for loop, an y=f(x) could be created for each point then passed out of the loop to the XY Graph.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(1,682 Views)
