09-11-2013 05:20 AM
Dear All,
I'm using Labview 8.2.1.
I have program where data are displayed on Graph.
When I Minimize the Window, data fo the graph are not refresh.
Please see attached file.
Thanks for your help.
Solved! Go to Solution.
09-11-2013 05:51 AM
Try changing the chart update mode from Scope to Strip Chart (Advanced > Update Mode). I believe this will prevent this from happening.
09-11-2013 06:09 AM
I think Thoult is right. change to strip chart mode.When the VI is running right click and shange the mode.
09-11-2013 07:09 AM
Dear All,
I have modify the Update mode, and When I set values for update mode "Strip—Shows" or "Sweep" the problem doesn't appear.
If I want to use "Scope" mode the problem appear. Does anybody know how to avoid this problem ?
I also try the program with LabView 2012 SP1, and the same problem appear.
I have modify the parameter of my computer Video card... but nothing change
Thanks all to have take time to reply.
Regards
09-12-2013 03:13 AM
Hello __KB__,
Use the ForceRedraw method in order to refresh your graph :
Here the help of this method : Force Redraw Method
Jérémy C.
NI France
09-12-2013 04:00 AM
Thanks for reply.
Yes It run with "force redraw" method ![]()
Unfortunately this method doesn't exist in version LV 8.2.1.
Regards
