Graph for parallel loops
Hi, I have a problem!
Actually i have two sequential while loops and i see the plot at the end of the second loop.
If i put the graph inside the loop i need two different xy graphs, so is it possibile to have only a unique real time graph?
Enrico.
Message 1 of 12
(4,659 Views)
Hi Enrico, what is a sequential while loop? If you are gathering data in 2 separate loops and you want to graph the data, you can create a 3rd loop to send the data to and graph it.
Message 2 of 12
(4,652 Views)
I have two different loop. Until now i can see at the end of the script my graph, instead i would like to see run time my graph. A solution could be to put 2 different graphs inside the two different loops but i prefer only one graph. Is it possibile?
PS: Sequential means that i run first a loop and than the other one, they are not in parallel.
Message 3 of 12
(4,645 Views)
Show us some code.
Message 4 of 12
(4,640 Views)
As Gregory suggested you could use a 3rd loop (parallel to the other two loops) and send the data to it for graphing. I believe that you could also use a state machine architecture to do what you want. For better answers you need to attach your code.
Message 5 of 12
(4,619 Views)
Currently i can't post vi because i'm not at home for two days.
I will try to explain better my problem: the goal of my vi is to make a polarization curve (back and forth). At the moment i have two different graphs because the two loops are not running at the same time. The point is that i would like to plot in real time the first curve and then the other one on the same graph. How can i solve my problem? Making a third loop of course i lose the concept of real time.
Message 6 of 12
(4,566 Views)
A pair of producers and a single consumer (Producer/Consumer) with the graph in the consumer will do what you want:
This is a fairly basic example, but you could also for example pass a plot index, and use an array of plots to have multiple plots on your graph (for different colours, etc).
GCentral
Message 7 of 12
(4,551 Views)
All you need is exactly one while loop and a state machine architecture. Build up the graphs in a suitable data structure in a shift register and display with each iteration. Update the relevant data depending on the state.
Message 8 of 12
(4,540 Views)
This is What i need. Can you send me this vi? Thanks
Message 9 of 12
(4,518 Views)
You didn't say who (or even use kudos to make a suggestion), but I'm guessing you meant my image.
Unfortunately I didn't save it, and it wasn't a snippet (darn! 😞 ) so I had to recreate it from scratch.
As a result, I decided to add the multiple indices. You can add or remove as desired.
Since this one is a snippet, it should be draggable onto a block diagram.
A 2015 copy is attached just in case.
GCentral
Message 10 of 12
(4,497 Views)
