Graph Waveform Arrays
I want to have the Graph of an array of measurments. I measure the power loss in channels A and B as an SWR value.
This value changes as I change the frequency externally.
how can I have thegraph of the whole range of measurements, could I give an array list of frequencies for input ?
please if any there 're any ideas...
(4,071 Views)
Hello Maj.
Do you want to plot different measurments in the same graph? If that is the case take a look at the vi attached.
If this is not the case. Could you please refrase the question?
Cheers
//Beckman
(4,061 Views)
unfortunately I can open the file you sent me, because my LabVIEW version is older 7.
The device I control through Labview changes the  values with frequency.
I just want to build a graph of those values, for the time being I just have one value of a percise Freq and I dont know how I could
make I graph.
I need to give a list of the frequencies and take the result graph of power changes.Could it be possible?
(4,049 Views)
Hello Maj,
1. You can write your frequencies to a text-file and then read it in to LabVIEW by using "Open/Create/Replace File", "Scan From File" or "Read File",  and "Close File". There are some other functions on your File I/O-palette that you can use.
2. There are some possibilites to view your data on a graph. You can read every single value from your instrument and write it to a file using e.g. "VISA Read To File" or something else from the Instrument I/O-palette. Then you can read the file (-> 1.) an display the data on a graph. Another possibility would be to read the data (e.g. "VISA read") and writing the data to an array wich you display on a graph. Using the XY-Graph requires specific data for the x- and y-axis that you can combine in a cluster and direct to an XY-Graph.
3. If your instrument can be controlled via GPIB, I suppose it will be possible to create a LabVIEW program wich solves your problem. Although I don't know your instrument, I'm quite sure there will be commands to set the frequencies numerically or a range of frequencies with a measurement distance. There can be possibilites to read all the measurement results at the end of all measurements and display them on a graph. Many manufacturers provide LabVIEW-Instrument-Drivers for there instruments. Perhaps you can get them for your instrument and LabVIEW-version.
If this can be a possibility for you, please let me know wich instruments you are using and how you realize the connection between the instrument and your computer.
I hope I could help you with my comments. If there are further questions, don't hesitate to post them.
District Sales Manager
(4,015 Views)
Thank you very much, your instructions were really helpfull.
I do have the drivers and I have done a GPIB connection with my device which is NRVD_857.8008.02
with the VI I use now I can only get the measurement value in each  frequency I switch in. I would now want to try making  a list of the values measured in a range of frequencies and draw the Graph of the measured object behavior.
(4,008 Views)
Hello Maj,
there should be an example coming with your LabVIEW-distribution called "Write to text file.vi" that gives an example how to write data to a file.
You can use the function "concatenate strings" to bring arrays of string together to one string that can be written to a text file. There is also a possibility to set the position for writing at the end of the file. This gives you the possibility to write measurement per measurement to the file as a set of frequency and SWR. After that it is no problem to view the data with LabVIEW or if you like any other program like Microsoft Excel.
I hope I understood your needs correctly and could give you some useful hints.
(4,001 Views)
