Graph Palette Button Size
Is there any way to re-size the graph palette buttons?  The cursor palette buttons are individual entities and can easily be re-sized, but not the pan/zoom/cursor buttons on the "graph palette".  I have a touch-screen and it would be helpful if these were larger.  I'm using LabView 7.1.
Brian
(3,785 Views)
Just open the graph in the control editor (right-click...advanced..customize) and go to edit mode. Now resize as needed.
  (This is from 8.0, but it works the same under 7.1)
Message Edited by altenbach on 06-11-2007 05:29 PM
(3,781 Views)
I went into the editor but was still unable to increase the size of the buttons, however I'm not very familiar with the editor...
Brian
(3,760 Views)
Once you are in the control editor, click on the button with the "wrench" and change to customize mode. Now you should be able to resize. Try it. 🙂
(3,756 Views)
Sorry, Got it now.   THANKS!
Brian
(3,754 Views)
