Graph Object Properties
I want to make a graph object look just like the screen of the
oscilloscope it's getting data from.
What property(s) of a graph object are used to set the number of
vertical & horizontal graticule lines?
(2,918 Views)
The LV graph grids are controlled by the scale min, max, and increment.
If you want four grids between min and max, set incr to (max - min)/5.
Greg McKaskle
(2,918 Views)
If you want to make the graph look _exactly_ like your scope you can do something similar to my example. Here I have placed a decoration at back, pasted an image of a scope on that, then a graph painted transparent (foreground and background) on top. You can use the picture controls/functions also to load your image dynamically behind a transparent graph.
(2,918 Views)
