Graph Autoscale Y Event
I am having a graph with multiple y scales. The user may change the setting 'autoscale' with the right-click context menu.
Neigther 'Scale Range Change' nor 'Autoscale Range Change' nor 'Plot Attribute Change' seems to catch this event.
Is there a way to fetch this change of settings within my event case structure?
(3,369 Views)
hi holger,
what do you want to do if you "catch the event"?
might it be feasible, that you let the user change the scale via an external method (like having a button that needs to be pressed, catch this and set the scale explicitly via property node)?
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,365 Views)
I want to synchronise all y scales to the same setting.
Right now I already have another control. Anytime this changes, all scales are set to 'autoscale' or 'manual scale'.
It might fit, if I can deactivate the 'Autoscale Y' setting from the context menu. I so, the user is forced to use the other control. If not, it might lead to confusion.
(3,362 Views)
it should be possible to set it with property node "Y Scale.Editable"
(3,356 Views)
Hi Holger,
Even better you could create your own context menu for the graph and handle all menu events on your own!
(3,345 Views)
