Graph Autoscale Bug/Feature?
Thanks.
What are the other CAR numbers?
I have posted the suggestion here.
I won't hold my breath...
Message 11 of 19
(2,534 Views)
The other CAR I created (for the Autoscale Y "Reverting") is: 381338
-Nathan
Systems Engineer
SISU
Message 12 of 19
(2,517 Views)
Hi Guys,
I believe I am suffering from this bug, and my numbers are quite normal, not of small amplitude at all. See the attached VI.
It is completely unpredictable to me when it's going to happen;  I'm maintaining a customer's VI, and this is quite maddening. Even with "Loose Fit" unchecked the behavior exhibits. Not sure what I can do to workaround short of writing my own autoscale function.
Message 13 of 19
(2,491 Views)
@pobrepablo1: I don't see anything out of the ordinary using LV 2012...
Message 14 of 19
(2,472 Views)
Drat, you're right. it's a 2011 bug that seems to have been fixed. Now to convine my work to upgrade...
Message 15 of 19
(2,465 Views)
As a side note, I tried your VI with LV 2011 SP1 and don't see the symptom you are talking about either (Windows XP)...
Message 16 of 19
(2,448 Views)
Strange, I notice on another machine with 2011 the problem doesn't appear. I have 2011 SP1 f1 patch on the affected machine, not f2 --- but I can't imagine that does it. Downloading f2 ppatch, Will report back.
Message 17 of 19
(2,443 Views)
I tested it with the f2 patch.
Message 18 of 19
(2,440 Views)
same issue after upgrade to f2 patch. bizarre.
Message 19 of 19
(2,427 Views)
