Grab and Basic Attribute Binning adjustment
In the example Grab and Basic Attribute, is Binning one of the attributes?  I cannot find it and I cannot even find it in the advanced attributes.  How can one adjust the binning, eg, 1x1, 2x2, 4x4, 8x8?  Thank you very much!
(2,768 Views)
Does your camera support to change the binning by software configuration?
Did you allready check your cameras attributes in MAX (View Options>All Attributes), and is binning stated there?
Christian
(2,750 Views)
I do not see an attribute called binning.  Does it have to do with video mode.  There's video mode setting with different pixels (attach in the picture).  What does this specify?
(2,740 Views)
I'm using Hamamatsu camera and they offer a Labview library to adjust the parameters.  However, it seems to me that it's difficult to use the vi's in that library because they have different open vi's
(2,735 Views)
I'm a bit confused now. Are you using NI IMAQ or the Hamamatsu driver now?
When using IMAQ and there is no parameter for Binning in the All Parameters list in MAX, then you cannot set it.
With the Hamamatsu driver, you allready posted the documentation for setting the binning.
Christian
(2,729 Views)
