Good method for detecting walls in a map
Good morning,
I'm spending a lot of time trying to convert a simple map into a set of segments in order to perform a Scan Matching with diferent robot poses for localization. I see there's a huge number of tools in Labview regarding Computer Vision and Pattern Matching but, until now, I can't find anything that satisfies my needs.
I tryed Edge Detection.vi but it returns not only the segment of wall but a complete line from side to side of the ROI as you can try in the example I attached. In addition, Edge detection doesn't work well with diagonal walls.
I could use Contour Detection.vi but it turns out that is computationally expensive according to perfermance profile plus it detects contours as points but I need lines because my map is composed of simple straight lines.
Finally I tried IMAQ Rake 3 but I don't know very well how it works and there's no examples of use in the examples folder.
Labview is an amazing programa with a lot of already made complex nodes, There must be a way to simulate what a robot equipped with a Laser Range Finder or LIDAR would see if running in a very simple 2D room.
Thanks in advance.
(2,790 Views)
hi
it's very popular and useful function which i am working on .
have you find any solution yet?
(2,584 Views)
