Go to new line with RT Debug String
Hi all, is it possible to go to a new line using RT Debug String.vi?
Claudio
(3,240 Views)
Hello Claudio,
if you go in Help under Index and search for °backslash codes display° you will find all the possible characters you can use.
The caracter you have to use is \n, for new line.
I found this information in the following link, that can be useful for you:
Can I Erase Characters Written Using Debug String?
http://digital.ni.com/public.nsf/allkb/71FA42B0BFAE6EB186256D98004D02D9?OpenDocument
Saluti,
Antonios
(3,221 Views)
Hi, I have tried this solution, but using special characters "\r" as the same effect of carriage return (from String palette) I've used before.
I write one string concatenated with "\r" and then I write a second string: the second write overwrite the first.
Is it possible to solve this issue?
Claudio
(3,216 Views)
Yes, you can use a Build array (under Programming ->Array), and every new string you write will be added to the next slot of the array. Did you try that?
Antonios
(3,214 Views)
How can I use an array as input for RT Debug String?
(3,210 Views)
Accepted by topic author hex_cro
you are right, i misunderstood. have you tried to use the "\n" as it is explained in the help ?
Antonios
(3,208 Views)
Can you take a look in the attached vi? Is this what you need?
Antonios
(3,204 Views)
