Global virtual channels and DAQmx AI inputs
I would like to see and example linking global virtual channels and input configuration for DAQmx AI inputs.  The DAQmx input requires physical channels and not global virtual channels.
(2,660 Views)
Hello rlbrehm,
If you are using a global virtual channel then you have alredy set up the input configuration, as shown here:
So you simply need to set up timing and read, as shown here and in the attached VI:
Message Edited by Dr. Doiron on 08-06-2009 02:55 PM
With warm regards,
David D.
(2,639 Views)
