Global - set default values during runtime
Is there a way to reinitialize a global variable to default values during runtime?
I know how to do it by passing the vi reference during developpement but with the exe, there is no more vi:)
Best regards
(4,994 Views)
Hi Tapitapo,
welcome to the forum!
Instead of using a method "Reinit to default" you could just write a (default) value to your global variable.
But then you are open for RaceConditions, when there is more than one place where the global is written to…
Why not replace the global by a FGV/FunctionalGlobalVariable aka AE/ActionEngine?
Why do you think there is no global VI in your exe? It should still be there, but just inside your EXE!
(4,983 Views)
Hello, thank you for the reply
- In case the global is modified, using a constant to initialize the global will force me to modify the vi, the "reinit to default" method no, minimum effort is better for me:)
- I use a global because it let me to be way more flexible during sql access. Only one AE will made my code a cable forest and is less modifiable, from my sight.
- The native code is embedded in the .exe after compilation of course, but there is no more vi as it is source, it is not possible to reference to the global.vi.
(4,971 Views)
Hi Tapitapo,
There will be no "cable forest": you have an AE VI/icon where you have the global variable icon right now. The same amount of wires…
In case the global is modified, using a constant to initialize the global will force me to modify the vi, the "reinit to default" method no, minimum effort is better for meSmiley Happy
It is just one more state of the AE. It is a one-time effort to incorporate that state in the AE.
It is even less effort to call the AE to execute that state when compared to calling the method with getting the needed reference !
The "native code" is embedded in the VI: each VI is compiled while you edit it!
And you still have all the VIs in the executable…
(4,962 Views)
You can look into config files for saving/initializing variables from an executable.
(4,907 Views)
