Gloabal variable can't change the value in an event structure
Put dataread.vi inside the main case structure so it runs alongside the while loop with the event structure, and just wire your start/stop global to the stop terminal in the subVI.  You'll need to either invert it or change the "stop if true" to a "continue if true."  This will stop the subVI when you click the stop switch and the main VI will go through the big loop without doing anything until you start it again.
Message 21 of 23
(592 Views)
Hey proffesional,
don't know what to do without you
thanks for everything,
But dont go away, i'll be back for some more , of course u can  help when u got the time,
But else i need all the help you can give!!
Thaanks !
Regards
Zamzam
HFZ
Message 22 of 23
(577 Views)
the thank was ofcourse for all
i ment proffesionals
HFZ
Message 23 of 23
(573 Views)
