Given the name of a cluster as a string create a property nodee
I select the name of a cluster from a text ring. Given the name of a cluster from the RingText.Text property of the ring, how do I generate a property node or access controls in the cluster?
Thank you.
Girish
(1,363 Views)
Hi Girish,
You need to:
  • get the references of all frontpanel elements
  • search the reference of your cluster by comparing the "Label" property with your string
  • using the reference of the cluster you get access to the cluster elements
(1,324 Views)
Is there a way to create an array of references of the desired clusters? Do I have to create a cluster consisting of label and reference, and create an array from the new cluster?
Thank you.
Girish
(1,299 Views)
Hi Girish,
Use a BuildArray node to build your array of references…
I don't understand this question!
What is this "new cluster of label and reference" used for?
(1,294 Views)
OK. I got it. From the reference access the label property and match it with the desired name.
Thank you.
Girish
(1,287 Views)
