GigE
I am using the Avt Manta G201c-30fps in Matlab and Labview. For some reason they both don’t show RGB24, BGR24 and Bayer16 formats.
The GigeViewer from AVT shows and runs the camera in all formats and I don’t understand why Matlab and Labview don’t pick up these formats.
(3,121 Views)
Hi There,
Thank you for your post. Are you able to see the "AVT Manta G201c-30fps" GigE camera in Meaurement and Automation Explorer (MAX)?
If you cannot you will not be able to communicate with the camera in LabVIEW, can I refer you to the tutorial "Troubleshooting GigE Vision Cameras".
What version of LabVIEW do you have installed?
Please keep me informed with these details.
Many Thanks
Jamie S.
(3,097 Views)
I take from the compatibility report here that these formats have not been tested.
Does IMAQdx support them anyway?
(3,085 Views)
I am using Labview 2009. The camera works in Meaurement and Automation Explorer (MAX) in some formats, but it does not show RGB24, BGR24 and Bayer16 formats in the options.
However, GigeViewer from AVT runs all formats fine.
(3,033 Views)
