Ghost dependency error [LabVIEW 2016]
one of the sub VI in my project is using the "report generation palette" with the function "New report.vi".
When I created this sub VI, I originally copy pasted pieces of code from an example found on the web which was showing how to manipulate Excel files with the "report generation palette" functions. Therefore the "New report.vi" was saved on the project as an independent sub VI (not in a library).
Later on, I removed the "New report.vi" sub function to replace it with the "New report.vi" from the "NI_report.lvclass" ("NI_report.lvclass" was added to my project automatically because I added the function from the "report generation palette", I guess).
Everything was fine, but then at some point, when opening any of the VIs of my project, I always get a dependency error which tells me that a sub VI "New report.vi" is missing. But the all VIs can be opened anyway and everything is running perfectly well.
The dependency actually disappear right after the error message (I guess the VI is loading with the "New report.vi" from the  "NI_report.lvclass" automatically, but then I don't understand why this change of dependency is never saved in the project..."
enclosed is a screen shot of the dependency error message I get when opening any VI (even the one having nothing to do with this "New report.vi" function) and then a screenshot of my project dependency folder where the VI which causes the error appears for a couple of second and then disappear automatically when the VI is fully loaded.
The project kept in memory that the sub function "New report.vi" is linked to this sub VI which no longer exist and does not want to keep in memory that it should use the "New report.vi" from the  "NI_report.lvclass" instead. Problem is that the dependency file error disappear so that I can't manually relink the "New report.vi" to the one of  "NI_report.lvclass".
If you have some tips...
thanks
regards,
Hicham
Message 1 of 8
(6,575 Views)
Those problems can be quite persistant, but generally, once this has relinked, File menu -> Save all to save VI's with the new dependancy. Ctrl+Run arrow on main program to force compile can also help (then Save all).
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(6,568 Views)
thanks for the answer.
When I make "explore" on the "New report.vi" it finds it in the lvclass, no problem. I can run the main VI or even the sub VI, no problem. I save all, no problem.
But if I close the VI and try to re open it, I still get the same error message...
Message 3 of 8
(6,535 Views)
Did you try to do Mass Compile (Tools -> Advanced -> Mass Compile) of the report generation library? Maybe, it can force it to load "missing" VI from proper place. It's just an idea, maybe it'll help...
This issue can be also b/c of different versions of report generation toolkit - what you use, and what you had in the example (and by loading VIs from example, it just messed up installed report generation toolkit...
Message 4 of 8
(6,528 Views)
NOTE: LabVIEW ninja trick not for the faint-hearted.  Don't try what you are about to see at home,. We are experts with years of training.
Spoiler
Or, go ahead and try it but don't blame me for the outcome
When you see that error.  Close the project without saving.  Open the lvproj with notepad search for the missing vi name.
Post that text here.  Depending on what we see, we can advise further.
"Should be" isn't "Is" -Jay
Message 5 of 8
(6,521 Views)
Mass compile does not have any effect...
Here is the notepad of lvproj closed after getting the error. But there is no "New report.vi" in it, just from lvclass of report toolkick and llb.
<?xml version='1.0' encoding='UTF-8'?>
<Project Type="Project" LVVersion="16008000">
<Property Name="varPersistentID:{5D07B823-0E98-449E-8218-9D07692DAB3F}" Type="Ref">/My Computer/Main Front Page Selection/Network Variables (main front page)/network variables (main front page).lvlib/net_var_test_1</Property>
<Property Name="varPersistentID:{9211CDE1-7AB8-4A88-BFC3-898198F8D90C}" Type="Ref">/My Computer/Main Front Page Selection/Manage List Active VIs (main front page)/Manage List Active VIs (main front page).lvlib/list active VIs and ports</Property>
<Item Name="My Computer" Type="My Computer">
<Property Name="server.app.propertiesEnabled" Type="Bool">true</Property>
<Property Name="server.control.propertiesEnabled" Type="Bool">true</Property>
<Property Name="server.tcp.enabled" Type="Bool">false</Property>
<Property Name="server.tcp.port" Type="Int">0</Property>
<Property Name="server.tcp.serviceName" Type="Str">My Computer/VI Server</Property>
<Property Name="server.tcp.serviceName.default" Type="Str">My Computer/VI Server</Property>
<Property Name="server.vi.callsEnabled" Type="Bool">true</Property>
<Property Name="server.vi.propertiesEnabled" Type="Bool">true</Property>
<Property Name="specify.custom.address" Type="Bool">false</Property>
<Item Name="Barometer M2104" Type="Folder" URL="../Barometer M2104">
<Property Name="NI.DISK" Type="Bool">true</Property>
</Item>
<Item Name="Help files" Type="Folder" URL="../Help files">
</Item>
<Item Name="Local Computer Instrument Detection" Type="Folder" URL="../Local Computer Instrument Detection">
</Item>
<Item Name="Main Front Page Selection" Type="Folder" URL="../Main Front Page Selection">
</Item>
<Item Name="Template Instrument" Type="Folder" URL="../Template Instrument">
</Item>
<Item Name="NI_report.lvclass" Type="LVClass" URL="/&lt;vilib&gt;/Utility/NIReport.llb/NI_report.lvclass"/>
<Item Name="Dependencies" Type="Dependencies">
<Item Name="vi.lib" Type="Folder">
<Item Name="Application Directory.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/file.llb/Application Directory.vi"/>
<Item Name="Bit-array To Byte-array.vi" Type="VI" URL="/&lt;vilib&gt;/picture/pictutil.llb/Bit-array To Byte-array.vi"/>
<Item Name="BuildHelpPath.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/BuildHelpPath.vi"/>
<Item Name="Built App File Layout.vi" Type="VI" URL="/&lt;vilib&gt;/AppBuilder/Built App File Layout.vi"/>
<Item Name="Calc Long Word Padded Width.vi" Type="VI" URL="/&lt;vilib&gt;/picture/bmp.llb/Calc Long Word Padded Width.vi"/>
<Item Name="Channel Abort Instructions.ctl" Type="VI" URL="/&lt;vilib&gt;/ChannelSupport/Channel Abort Instructions.ctl"/>
<Item Name="Check Color Table Size.vi" Type="VI" URL="/&lt;vilib&gt;/picture/jpeg.llb/Check Color Table Size.vi"/>
<Item Name="Check Data Size.vi" Type="VI" URL="/&lt;vilib&gt;/picture/jpeg.llb/Check Data Size.vi"/>
<Item Name="Check File Permissions.vi" Type="VI" URL="/&lt;vilib&gt;/picture/jpeg.llb/Check File Permissions.vi"/>
<Item Name="Check if File or Folder Exists.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/libraryn.llb/Check if File or Folder Exists.vi"/>
<Item Name="Check Path.vi" Type="VI" URL="/&lt;vilib&gt;/picture/jpeg.llb/Check Path.vi"/>
<Item Name="Check Special Tags.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Check Special Tags.vi"/>
<Item Name="Clear Errors.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Clear Errors.vi"/>
<Item Name="Close Registry Key.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Close Registry Key.vi"/>
<Item Name="Color to RGB.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/colorconv.llb/Color to RGB.vi"/>
<Item Name="compatCalcOffset.vi" Type="VI" URL="/&lt;vilib&gt;/_oldvers/_oldvers.llb/compatCalcOffset.vi"/>
<Item Name="compatFileDialog.vi" Type="VI" URL="/&lt;vilib&gt;/_oldvers/_oldvers.llb/compatFileDialog.vi"/>
<Item Name="compatOpenFileOperation.vi" Type="VI" URL="/&lt;vilib&gt;/_oldvers/_oldvers.llb/compatOpenFileOperation.vi"/>
<Item Name="compatOverwrite.vi" Type="VI" URL="/&lt;vilib&gt;/_oldvers/_oldvers.llb/compatOverwrite.vi"/>
<Item Name="Convert property node font to graphics font.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Convert property node font to graphics font.vi"/>
<Item Name="Create ActiveX Event Queue.vi" Type="VI" URL="/&lt;vilib&gt;/Platform/ax-events.llb/Create ActiveX Event Queue.vi"/>
<Item Name="Create Error Clust.vi" Type="VI" URL="/&lt;vilib&gt;/Platform/ax-events.llb/Create Error Clust.vi"/>
<Item Name="Create Mask By Alpha.vi" Type="VI" URL="/&lt;vilib&gt;/picture/picture.llb/Create Mask By Alpha.vi"/>
<Item Name="Destroy ActiveX Event Queue.vi" Type="VI" URL="/&lt;vilib&gt;/Platform/ax-events.llb/Destroy ActiveX Event Queue.vi"/>
<Item Name="Details Display Dialog.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Details Display Dialog.vi"/>
<Item Name="Dflt Data Dir.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/file.llb/Dflt Data Dir.vi"/>
<Item Name="DialogType.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/DialogType.ctl"/>
<Item Name="DialogTypeEnum.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/DialogTypeEnum.ctl"/>
<Item Name="Directory of Top Level VI.vi" Type="VI" URL="/&lt;vilib&gt;/picture/jpeg.llb/Directory of Top Level VI.vi"/>
<Item Name="Error Cluster From Error Code.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Error Cluster From Error Code.vi"/>
<Item Name="Error Code Database.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Error Code Database.vi"/>
<Item Name="ErrWarn.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/ErrWarn.ctl"/>
<Item Name="Escape Characters for HTTP.vi" Type="VI" URL="/&lt;vilib&gt;/printing/PathToURL.llb/Escape Characters for HTTP.vi"/>
<Item Name="EventData.ctl" Type="VI" URL="/&lt;vilib&gt;/Platform/ax-events.llb/EventData.ctl"/>
<Item Name="eventvkey.ctl" Type="VI" URL="/&lt;vilib&gt;/event_ctls.llb/eventvkey.ctl"/>
<Item Name="ex_CorrectErrorChain.vi" Type="VI" URL="/&lt;vilib&gt;/express/express shared/ex_CorrectErrorChain.vi"/>
<Item Name="Find Tag.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Find Tag.vi"/>
<Item Name="FindCloseTagByName.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/FindCloseTagByName.vi"/>
<Item Name="FindElement.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/FindElement.vi"/>
<Item Name="FindElementStartByName.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/FindElementStartByName.vi"/>
<Item Name="FindEmptyElement.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/FindEmptyElement.vi"/>
<Item Name="FindFirstTag.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/FindFirstTag.vi"/>
<Item Name="FindMatchingCloseTag.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/FindMatchingCloseTag.vi"/>
<Item Name="Flip and Pad for Picture Control.vi" Type="VI" URL="/&lt;vilib&gt;/picture/bmp.llb/Flip and Pad for Picture Control.vi"/>
<Item Name="Format Message String.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Format Message String.vi"/>
<Item Name="General Error Handler Core CORE.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/General Error Handler Core CORE.vi"/>
<Item Name="General Error Handler.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/General Error Handler.vi"/>
<Item Name="Generate Temporary File Path.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/libraryn.llb/Generate Temporary File Path.vi"/>
<Item Name="Get File Extension.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/libraryn.llb/Get File Extension.vi"/>
<Item Name="Get LV Class Default Value.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/LVClass/Get LV Class Default Value.vi"/>
<Item Name="Get String Text Bounds.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Get String Text Bounds.vi"/>
<Item Name="Get Text Rect.vi" Type="VI" URL="/&lt;vilib&gt;/picture/picture.llb/Get Text Rect.vi"/>
<Item Name="GetHelpDir.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/GetHelpDir.vi"/>
<Item Name="GetRTHostConnectedProp.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/GetRTHostConnectedProp.vi"/>
<Item Name="Handle Open Word or Excel File.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/NIReport.llb/Toolkit/Handle Open Word or Excel File.vi"/>
<Item Name="High Resolution Relative Seconds.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/High Resolution Relative Seconds.vi"/>
<Item Name="imagedata.ctl" Type="VI" URL="/&lt;vilib&gt;/picture/picture.llb/imagedata.ctl"/>
<Item Name="Is Path and Not Empty.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/file.llb/Is Path and Not Empty.vi"/>
<Item Name="Longest Line Length in Pixels.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Longest Line Length in Pixels.vi"/>
<Item Name="Lossy Behavior.ctl" Type="VI" URL="/&lt;vilib&gt;/ChannelSupport/Lossy Behavior.ctl"/>
<Item Name="LVAnnotationListTypeDef.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/miscctls.llb/LVAnnotationListTypeDef.ctl"/>
<Item Name="LVBoundsTypeDef.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/miscctls.llb/LVBoundsTypeDef.ctl"/>
<Item Name="lvpidtkt.dll" Type="Document" URL="/&lt;vilib&gt;/addons/control/pid/lvpidtkt.dll"/>
<Item Name="LVPointTypeDef.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/miscctls.llb/LVPointTypeDef.ctl"/>
<Item Name="LVPositionTypeDef.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/miscctls.llb/LVPositionTypeDef.ctl"/>
<Item Name="LVRectTypeDef.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/miscctls.llb/LVRectTypeDef.ctl"/>
<Item Name="NI_AALPro.lvlib" Type="Library" URL="/&lt;vilib&gt;/Analysis/NI_AALPro.lvlib"/>
<Item Name="NI_Excel.lvclass" Type="LVClass" URL="/&lt;vilib&gt;/Utility/NIReport.llb/Excel/NI_Excel.lvclass"/>
<Item Name="NI_FileType.lvlib" Type="Library" URL="/&lt;vilib&gt;/Utility/lvfile.llb/NI_FileType.lvlib"/>
<Item Name="NI_Gmath.lvlib" Type="Library" URL="/&lt;vilib&gt;/gmath/NI_Gmath.lvlib"/>
<Item Name="NI_HTML.lvclass" Type="LVClass" URL="/&lt;vilib&gt;/Utility/NIReport.llb/HTML/NI_HTML.lvclass"/>
<Item Name="NI_PackedLibraryUtility.lvlib" Type="Library" URL="/&lt;vilib&gt;/Utility/LVLibp/NI_PackedLibraryUtility.lvlib"/>
<Item Name="NI_PID__prctrl compat.lvlib" Type="Library" URL="/&lt;vilib&gt;/addons/control/pid/NI_PID__prctrl compat.lvlib"/>
<Item Name="NI_PID_pid.lvlib" Type="Library" URL="/&lt;vilib&gt;/addons/control/pid/NI_PID_pid.lvlib"/>
<Item Name="NI_ReportGenerationCore.lvlib" Type="Library" URL="/&lt;vilib&gt;/Utility/NIReport.llb/NI_ReportGenerationCore.lvlib"/>
<Item Name="NI_ReportGenerationToolkit.lvlib" Type="Library" URL="/&lt;vilib&gt;/addons/_office/NI_ReportGenerationToolkit.lvlib"/>
<Item Name="NI_Standard Report.lvclass" Type="LVClass" URL="/&lt;vilib&gt;/Utility/NIReport.llb/Standard Report/NI_Standard Report.lvclass"/>
<Item Name="Not Found Dialog.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Not Found Dialog.vi"/>
<Item Name="OccFireType.ctl" Type="VI" URL="/&lt;vilib&gt;/Platform/ax-events.llb/OccFireType.ctl"/>
<Item Name="Open Registry Key.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Open Registry Key.vi"/>
<Item Name="Open_Create_Replace File.vi" Type="VI" URL="/&lt;vilib&gt;/_oldvers/_oldvers.llb/Open_Create_Replace File.vi"/>
<Item Name="ParseXMLFragments.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/ParseXMLFragments.vi"/>
<Item Name="Path to URL.vi" Type="VI" URL="/&lt;vilib&gt;/printing/PathToURL.llb/Path to URL.vi"/>
<Item Name="Read From XML File(array).vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/Read From XML File(array).vi"/>
<Item Name="Read From XML File(string).vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/Read From XML File(string).vi"/>
<Item Name="Read From XML File.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/Read From XML File.vi"/>
<Item Name="Read JPEG File.vi" Type="VI" URL="/&lt;vilib&gt;/picture/jpeg.llb/Read JPEG File.vi"/>
<Item Name="Read PNG File.vi" Type="VI" URL="/&lt;vilib&gt;/picture/png.llb/Read PNG File.vi"/>
<Item Name="Read Registry Value DWORD.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Read Registry Value DWORD.vi"/>
<Item Name="Read Registry Value Simple STR.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Read Registry Value Simple STR.vi"/>
<Item Name="Read Registry Value Simple U32.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Read Registry Value Simple U32.vi"/>
<Item Name="Read Registry Value Simple.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Read Registry Value Simple.vi"/>
<Item Name="Read Registry Value STR.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Read Registry Value STR.vi"/>
<Item Name="Read Registry Value.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Read Registry Value.vi"/>
<Item Name="Registry Handle Master.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Registry Handle Master.vi"/>
<Item Name="Registry refnum.ctl" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Registry refnum.ctl"/>
<Item Name="Registry RtKey.ctl" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Registry RtKey.ctl"/>
<Item Name="Registry SAM.ctl" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Registry SAM.ctl"/>
<Item Name="Registry Simplify Data Type.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Registry Simplify Data Type.vi"/>
<Item Name="Registry View.ctl" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Registry View.ctl"/>
<Item Name="Registry WinErr-LVErr.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/Registry WinErr-LVErr.vi"/>
<Item Name="Search and Replace Pattern.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Search and Replace Pattern.vi"/>
<Item Name="Set Bold Text.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Set Bold Text.vi"/>
<Item Name="Set Busy.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/cursorutil.llb/Set Busy.vi"/>
<Item Name="Set Cursor (Cursor ID).vi" Type="VI" URL="/&lt;vilib&gt;/Utility/cursorutil.llb/Set Cursor (Cursor ID).vi"/>
<Item Name="Set Cursor (Icon Pict).vi" Type="VI" URL="/&lt;vilib&gt;/Utility/cursorutil.llb/Set Cursor (Icon Pict).vi"/>
<Item Name="Set Cursor.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/cursorutil.llb/Set Cursor.vi"/>
<Item Name="Set String Value.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Set String Value.vi"/>
<Item Name="Simple Error Handler.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Simple Error Handler.vi"/>
<Item Name="Space Constant.vi" Type="VI" URL="/&lt;vilib&gt;/dlg_ctls.llb/Space Constant.vi"/>
<Item Name="STR_ASCII-Unicode.vi" Type="VI" URL="/&lt;vilib&gt;/registry/registry.llb/STR_ASCII-Unicode.vi"/>
<Item Name="subFile Dialog.vi" Type="VI" URL="/&lt;vilib&gt;/express/express input/FileDialogBlock.llb/subFile Dialog.vi"/>
<Item Name="System Exec.vi" Type="VI" URL="/&lt;vilib&gt;/Platform/system.llb/System Exec.vi"/>
<Item Name="TagReturnType.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/TagReturnType.ctl"/>
<Item Name="Three Button Dialog CORE.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Three Button Dialog CORE.vi"/>
<Item Name="Three Button Dialog.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Three Button Dialog.vi"/>
<Item Name="Trim Whitespace.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Trim Whitespace.vi"/>
<Item Name="Unset Busy.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/cursorutil.llb/Unset Busy.vi"/>
<Item Name="Wait On ActiveX Event.vi" Type="VI" URL="/&lt;vilib&gt;/Platform/ax-events.llb/Wait On ActiveX Event.vi"/>
<Item Name="Wait types.ctl" Type="VI" URL="/&lt;vilib&gt;/Platform/ax-events.llb/Wait types.ctl"/>
<Item Name="whitespace.ctl" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/whitespace.ctl"/>
<Item Name="Write BMP Data To Buffer.vi" Type="VI" URL="/&lt;vilib&gt;/picture/bmp.llb/Write BMP Data To Buffer.vi"/>
<Item Name="Write BMP Data.vi" Type="VI" URL="/&lt;vilib&gt;/picture/bmp.llb/Write BMP Data.vi"/>
<Item Name="Write BMP File.vi" Type="VI" URL="/&lt;vilib&gt;/picture/bmp.llb/Write BMP File.vi"/>
<Item Name="Write JPEG File.vi" Type="VI" URL="/&lt;vilib&gt;/picture/jpeg.llb/Write JPEG File.vi"/>
<Item Name="Write PNG File.vi" Type="VI" URL="/&lt;vilib&gt;/picture/png.llb/Write PNG File.vi"/>
<Item Name="Write to XML File(array).vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/Write to XML File(array).vi"/>
<Item Name="Write to XML File(string).vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/Write to XML File(string).vi"/>
<Item Name="Write to XML File.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/xml.llb/Write to XML File.vi"/>
</Item>
<Item Name="_ChannelSupport.lvlib" Type="Library" URL="/&lt;resource&gt;/ChannelSupport/_ChannelSupport/_ChannelSupport.lvlib"/>
<Item Name="Advapi32.dll" Type="Document" URL="Advapi32.dll">
<Property Name="NI.PreserveRelativePath" Type="Bool">true</Property>
</Item>
<Item Name="ChannelProbePositionAndTitle.vi" Type="VI" URL="/&lt;resource&gt;/ChannelSupport/_ChannelSupport/ChannelProbePositionAndTitle.vi"/>
<Item Name="ChannelProbeWindowStagger.vi" Type="VI" URL="/&lt;resource&gt;/ChannelSupport/_ChannelSupport/ChannelProbeWindowStagger.vi"/>
<Item Name="High Speed Stream-t&apos;raw data from device (M2104).ctl&apos;.lvlib" Type="Library" URL="/&lt;extravilib&gt;/ChannelInstances/High Speed Stream-t&apos;raw data from device (M2104).ctl&apos;.lvlib"/>
<Item Name="High Speed Stream-t&apos;raw data from device (template instrument).ctl&apos;.lvlib" Type="Library" URL="/&lt;extravilib&gt;/ChannelInstances/High Speed Stream-t&apos;raw data from device (template instrument).ctl&apos;.lvlib"/>
<Item Name="High Speed Stream-t&apos;treated data (M2104).ctl&apos;.lvlib" Type="Library" URL="/&lt;extravilib&gt;/ChannelInstances/High Speed Stream-t&apos;treated data (M2104).ctl&apos;.lvlib"/>
<Item Name="High Speed Stream-t&apos;treated data (template instrument).ctl&apos;.lvlib" Type="Library" URL="/&lt;extravilib&gt;/ChannelInstances/High Speed Stream-t&apos;treated data (template instrument).ctl&apos;.lvlib"/>
<Item Name="kernel32.dll" Type="Document" URL="kernel32.dll">
</Item>
<Item Name="Lossy Stream-t&apos;treated data (M2104).ctl&apos;.lvlib" Type="Library" URL="/&lt;extravilib&gt;/ChannelInstances/Lossy Stream-t&apos;treated data (M2104).ctl&apos;.lvlib"/>
<Item Name="Lossy Stream-t&apos;treated data (template instrument).ctl&apos;.lvlib" Type="Library" URL="/&lt;extravilib&gt;/ChannelInstances/Lossy Stream-t&apos;treated data (template instrument).ctl&apos;.lvlib"/>
<Item Name="lvanlys.dll" Type="Document" URL="/&lt;resource&gt;/lvanlys.dll"/>
<Item Name="PipeLogic.lvclass" Type="LVClass" URL="/&lt;resource&gt;/ChannelSupport/_ChannelSupport/PipeLogic/PipeLogic.lvclass"/>
<Item Name="ProbeFormatting.vi" Type="VI" URL="/&lt;resource&gt;/ChannelSupport/_ChannelSupport/ProbeSupport/ProbeFormatting.vi"/>
<Item Name="Stream.lvlib" Type="Library" URL="/&lt;resource&gt;/Channels/Stream/Stream.lvlib"/>
<Item Name="Update Probe Details String.vi" Type="VI" URL="/&lt;resource&gt;/ChannelSupport/_ChannelSupport/ProbeSupport/Update Probe Details String.vi"/>
</Item>
<Item Name="Build Specifications" Type="Build"/>
</Item>
</Project>
Message 6 of 8
(6,507 Views)
Go to New report.vi after opening the VI and it loads the New report.vi.
-Right click on the vi and click on Find all instances and make sure all are referencing to the New report.vi from the .lvclass(Right Click Call set up and verify the path)
-Somewhere still there is a place where you have New report.vi which is still trying to load from the said path and when it is not able to load it from there then it is trying the one in .lvclass.
-Save all(This Project) and then reload it and check.
uday
Message 7 of 8
(6,495 Views)
I see that.  It looks like you've managed to corrupt  NIReport.llb <LabVIEW xxxx>\vi.llb\Utility\NIReport.llb\  where NI_report.lvclass is somehow linked to an oldvers of New Report.vi.
New Report.vi has some funky sub.vis that are used to dynamically load Office report class plugins- I suspect the original source you copied from an online example caused the conflict.
A repair pf the LabVIEW install "Should" correct it.  If Not, uninstall RG TK, Delete, that folder from vi.llb and re-install the TK.
@HINT: for evidence to support theory.  Check the Date Modified properties in the folder via Windows explorer.  If they look funky (not @ 6/8/2016 for vis and 9/8/2016 for folders) my magic 8-ball is well calibrated and the above methods should fix your issue.
Then try to avoid saving vis in vi.llb in the future.
Message 8 of 8
(6,481 Views)
