Getting values ​​into a table and sorting
Hello! I am totally new to this software and the truth is I'm lost 😧
I have to do something that sounds very simple (and maybe it is) but I know nothing is complicated.
What should I do is is a  collect data (valors), put them in a table and fits from first to last place, or from last place to first place. I can make the table and this will take random data, but it is not what I'm really want ...
I will appreciate your help with a very easy explanation for a novice like me 😧
Thank you very much!
(4,271 Views)
Accepted by topic author Miguel_Exe
Hello Miguel_Exe,
If you want to sort the array before putting it into the table then you can just use a sort array function as shown.table sort.pngtable sort FP.PNG
You can find the sort function in functions palette > programming > Arrays > Sort 1D array.
Let me know if this helps.
(4,255 Views)
Thank you very much it works really well!!! 😄
Last thing:
To enter a random value one by one, its possible? (In this, all are entered simultaneously)
Thank you!
(4,225 Views)
Something like this should work for you.
(4,222 Views)
I dont find these components :S
(4,204 Views)
Which components?  I just used the Build Array, Random Number (0-1), and Sort 1D Array.  I just stored the array in a shift register, which is just a way to pass data from one iteration of a loop to the next.  You create the shift register by right-clicking on the loop.
(4,196 Views)
Parfait! Thank you very much to the two! 😄
(4,191 Views)
