Getting slope
Does anyone have an example of getting slope/y-intercept from data populated in notepad using LabVIEW?
Thanks.
(2,791 Views)
You can use Read From Spreadsheet File on the File I/O palette and Linear Fit on the Analyze>Mathematics>Curve Fitting palette. The default delimiter for for Read From Spreadsheet is a tab character that you can cahnge and the attachment assumes that the X data is in column 1 and the Y data is in column 2. Modify as needed.
(2,787 Views)
