Getting shared variable name on Scan mode Compact Rio project
Using a compact rio in scan mode, I want to display the name of the channel I'm logging next to the value.
Since I use shared variable to get those channel values from the cRio, I'm not able to get the name of those variable as well (wich are define in the project). Presently, beside the numerical indicator of the value, I used text box to identify them.
How could I get those name so they could be associated to the numerical indicator by the mean of an string indicator???
Your help would be much appreciated!
Alexandre Lataille
Novabus
Alexandre Lataille
Novabus, Division of Volvo
(2,863 Views)
If you are using LV 8.6 you can use the Scan API found on NI labs. Use the Get Input Channel Value by Name function. More information can be foundhere.
With this, you know what IO Channel Nme you are calling and you know the value, so you can record both.
This functionality is built into labview 2009.
Andrew
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(2,844 Views)
