Getting object by having GObject Refnum values
Hi all,
I am trying to produce a XML file which contains all the objects(controls and Indicators) information. I have an array of all the GObject Refnums using Property Node, but I need to get objects out of these references. Does anyone have an idea how can I do that?
Pari sa
Message 1 of 11
(7,430 Views)
No one???
Does anyone know how to get object, let us say control having its reference??
Any help is appriciated...
Pari sa
Message 2 of 11
(7,404 Views)
You need the 'to more specific class' cast prim. Then check for all possible classes, and if you have no error, process the properties of the more specific class. Then do this again for the even more specific types and recurse through the tree.
There is also a property that gives you the class name, but then you only have the most specific class and not the traversion through the tree -> you'd need a lot of duplicate code.
Felix
Message 3 of 11
(7,398 Views)
Hey Felix,
thanks for your response. What about the output of 'to more specific class'? I have again a refnum!!!!! I need the object to pass it to the 'Flatten to XML'...
Pari sa
Message 4 of 11
(7,392 Views)
What exactly are you trying to pass to the Flatten to XML?
You normally take a reference, feed it into a property node or invoke node, and read or write the properties you need, or use whatever method you need if you are acting on the object with the invoke node.
Remember, the refnum is just a number that gets generated at runtime to distinguish the different objects from each other.  The to more specific class takes a refnum and says "this is not just a control object but more specifically a numeric control" so that when you wire the refnum into a property node or invoke node structure, LabVIEW knows what kinds of properties and methods to make available to you.
Message 5 of 11
(7,388 Views)
Try this:
1.) Use the Controls[] Property instead of All Objects[] so you can avoid To More Specific Class
2.) For each control reference (ie. For Loop) use the Value property, this will be a Variant which can be passed straight to Flatten To XML
Message 6 of 11
(7,382 Views)
Hey all,
I want to convert a VI to an XML file. Wiring a control to Flatten to XML, I will have sth like:
<DBL>
<Name>TestNum</Name>
<Val>0.00000000000000</Val>
</DBL>
I want to have same information for all of the exsiting controls and indicators in the VI, putting them together and produce the XML file. With the help of Property Node I get an array of all of the existing objects... but an array of refnums...
Using Value property does not help either as it has only the Val information. Any other ideas?!?!
Cheers,
Pari sa
Message 7 of 11
(7,347 Views)
have a look at this code. I guess you can format this outputs into XML and do what you want. Below is also attached the png as snip it for LabVIEW 2009.
LabVIEW 2010 Code
Regards
TomBaum
Message 8 of 11
(7,317 Views)
Accepted by topic author pari sa
I don't know what you mean by Value Property has only the Val information, if you follow my instructions you see that the Value is a variant with all of the info you get by wiring the control directly, with a little extra since it is wrapped in a variant.  See example where I also show a quick way to remove the variant wrapper which helps readability, but I would skip this if you want to read the file later and reverse the process.
Message 9 of 11
(7,295 Views)
Hey all,
thanks for your responses. Finally I have an XML file containing all the Control objects in the VI!
The last problem is that, is there any way to differentiate in the xml file between Controls and Indicators???
Cheers
Pari sa
Message 10 of 11
(7,278 Views)
