Getting error in Web publishing
I want to web publish one vi using web publishing toolkit. In this process I am getting following error please any one help to slove this problem
if I give "Yes" also I am not able to publish this
Message 1 of 8
(3,953 Views)
Hey,
Did you enable the WebServer under LabVIEW>Options>WebServer ?
Christian
Message 2 of 8
(3,941 Views)
Hi Christian,
Already i have enabled the WebServer
Message 3 of 8
(3,939 Views)
Are you sure that you set the following checkbox:
Christian
Message 4 of 8
(3,936 Views)
Yes i am sure about this i have selected. I am using LabVIEW 8.6 in that i have given bellow configuration please check this Web Config.JPG
Santhosh M
Message 5 of 8
(3,934 Views)
Hey,
So you enabled the Webserver, then you go to  Tools>Web Publishing Tool, then you get this dialog telling you that you have to enable the server, and then?
Are you able to build the webpage though and you just cannot connect to it?
Christian
Message 6 of 8
(3,932 Views)
             Yes, I am able build webpage but not ablt to connect. i dont know where is the problem please help to slove this
Santhosh M
Message 7 of 8
(3,928 Views)
Ok, that makes more sense now.
Do you use the same machine where you create the website to test this?
What browser do you use?
What do you type into the browse field?
What do you see when connecting to the webpage?
Christian
Message 8 of 8
(3,925 Views)
