07-10-2013 02:57 AM
In the testpanel of NI-max we tried, but every time we are getting 10v, but the thing is if i remove the cable connection then voltage is vary in between 10 to -10v.
i have off the system power so initially i should get 0v but i didnt.
and i have connected multimeter with the pin 30 and 29 for ai3 in that i can read 0v but in control panel i see 10v every time here in attachmet i have attach that dia.
please guide me i am very confuce about this, i think i am missing some basic concept for that.
thank you very much in advance.
07-10-2013 07:45 AM
07-11-2013 01:57 AM
Thank you very much.
ya it might be setting problem.
I have set In test panel RSE and it seems voltage at 0v which i want and if i set differential then its show 10v si i got confused over there.
but In RSE its show 0v which i was expect.
thank you very much once again.
