Getting error 1172 while calling c# dll in LabVIEW using .NET API
I build c# project and exported all dlls. When I am trying to call it from LabVIEW using .net API, I am getting error as below. Is there any specific setting required while building project ?
(1,649 Views)
Error 1172 generally occurs when there is an exception thrown inside your .NET assembly.
There should be a detailed explanation in the error string that may help you understand what goes wrong inside your dll.
(1,609 Views)
I've the same problem and nothing wrong on my dll cause I use it on a c# project without any problem.
I've the following message:
Nœud de méthode System.Reflection.TargetInvocationException: Une exception a été levée par la cible d'un appel.
(1,523 Views)
https://forums.ni.com/t5/Discussions-au-sujet-de-NI/error-1172-appel-d-une-fonction-dll/td-p/3801612
Rolf Kalbermatter  My Blog
(1,519 Views)
