Getting error –10240 WDAQCONF using Ni daq 4.3.2 and LabVIEW 3.1.1
Getting error –10240 WDAQCONF cannot find the NI-DAQ DLL
Installed Ni daq 4.3.2 using LabVIEW 3.1.1. The DAQ board is a LAB_PC+
Any Ideas. We want to upgrade but it will take time to get the money approved.
(2,578 Views)
Hey dksys2000,
It looks like quite an old setup you have there so it will be slightly more difficult to find documentation. Did this error all of sudden start happening or is this a new setup?
From the research that I have done it looks like the LabVIEW 3.1.1 installer installs a set of DAQ driver files that are guaranteed to work with LabVIEW. So if you happen to install an older version of the NI-DAQ drivers, you may run into problems. Let's first try uninstalling everything and then reinstalling only LabVIEW to see if this fixes the problem.
Chris Delvizis
(2,543 Views)
