Getting HTTP 400 Bad Request when trying to hit LV web service with a GET
Going through this tutorial:
https://zone.ni.com/reference/en-XX/help/371361R-01/lvhowto/build_web_service/#Creating_VIs_WS
Attempting to navigate to the method URL in IE results in an HTTP 400 Bad Request.
I've turned off all firewalls to see if that influences the result, but same issue remains.  I also tried both the application ports and debug (8080 and 8001).
Is there something I need to enable or configure in the environment/LV Web server?
(1,978 Views)
Accepted by topic author p27
had to change app web server from 32b to 64b
also don't forget to remove the curly braces from the method URL as well...
(1,933 Views)
