Getting Error -200284 in MAX when I select Continuous sampling
I have an application that was working on a XP computer, I moved the application and also MAX configuration to a new computer with Windows 7 operating system. I am having issues with an analog input task defined in MAX. When I select on demand for acquisition mode no issues I can see the data on the Graph, but when I select acquisition mode as continuous, I am getting error 200284. I don't understand why is this happening. I tried several different samples to acquire and sampling rate nothing worked. Please let me know what am I doing wrong here.
Mudda.
(2,284 Views)
Hi Mudda,
This error means that some or all of the samples requested have not yet been acquired. The sampling rate is set too low, try to increase it.
According to this article, the sample rate should be greater than Samples to Read/Timeout.
Best,
Carmen C.
(2,267 Views)
