Get waveform value at specific time
Hi ,I have an analog waveform and I would like to read the value at a specific time. ( Let's say 12s from start) . Is there any function that can directly do it for me instead of working on timestamps and dt
(3,794 Views)
There's always "Wait (ms)".
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(3,789 Views)
I assume the OP is looking for something similar to "index array" but with a time input instead of an index and a waveform instead of an array.
I think you need to make your own. Should be simple enough. 😉
(3,780 Views)
How about WDT Get XY Value DBL?
(3,778 Views)
That should do it. Set Y position format to "relative time". (of course if you look inside, all it does is what the OP is already doing) 😄
(Personally, I would actually implement interpolation in case the exact time point is not available...)
(3,772 Views)
