Get timestamp from EDF-file in LabVIEW
I need to get the timestamp info from EDF-files. The waveform signal does not seem to get this info from the EDF-file. I use "Open Data Storage" and "Read Data" express funtions. The signal is fine and the sample frequency is also correct, but it cannot read the start timestamp. what should I do?
I´m sure that the EDF-files has a timestamp cos it can be shown in the EDF-browser.
(Get Dynamic Data Attibutes - timestamp just show zeros..)
(2,188 Views)
Accepted by topic author jesboy
Hey Jesboy!
Kindly find attached the VI that will work for you!
Make sure to install Biomedical Standards DataPlugin for EuropeanDataFormat
(2,105 Views)
Thank you so much! Just what I wanted 🙂
(2,097 Views)
