Get pointer from an array for C DLL
The image has different sizes. It can be very small (140*168) but also bigger (520*640). It comes from an infrared cameras so the size is quite small compare to other cameras.
I have function on my DLL which give the size of the image so if LabVIEW is able to get a pointer, and through a "MoveFunction" or something like this recreate the image, I can deal with it. LabVIEW has only to display the result so I just have to recreate the image from the pointer.
Is other side, it is the same, I will have an image read on LabVIEW and want to send it to the DLL once for now.
For 32/64bits I agree but don't have the time for this, I have to do something working as quicker I can.
Mathieu Gauquelin
Message 11 of 15
(991 Views)
No disrespect to you, but "As quick as you can" may turn out to be never. If time is an issue it may be a good idea to hire someone for this aspect of the software, who has a sound understanding of both C programming and how to interface such things to LabVIEW.
Rolf Kalbermatter  My Blog
Message 12 of 15
(986 Views)
My company doesn't think like you and me... Which was funny when I was told I has to do this work. I will try to find a way with all your explanation.
Mathieu Gauquelin
Message 13 of 15
(981 Views)
Just like this, do you know if transfer a matrix of double instead of uint8/16 will be in the same way or more complex? ^^
Mathieu Gauquelin
Message 14 of 15
(972 Views)
The only difference is the size of the array element. So yes the principle is the same. But if you want to support multiple variants you will end up writing a VI for each datatype.
Message 15 of 15
(969 Views)
