Get issued to Common name from a website with X509 certificates
I am trying to get the "issued to" Common name from a website with labview. I can get the common name with PowerShell.
How can I do the same in labview. I tried using X509 certificates, but could build the the VI. Any help would be greatly appreciated.
Winnie
(631 Views)
If you can get the name using PowerShell, how about just calling PowerShell from LabVIEW?
Someone has done it before:
https://forums.ni.com/t5/LabVIEW/Run-windows-script-commands-in-Labview/m-p/4089966/highlight/true#M...
(594 Views)
Hi Kyle,
I actually use a batch file to run the scripts, I just thought I could just use the X509 certificates to get this done. If it cannot be done, I will stick with powershell. Thank you for reply.
thanks.
Winnie
(576 Views)
