Get every 10 sec a int.value and need to take the sum of the last 18 values
i get every 10 sec a int.value and need to take the sum of the last 18 values (3 minutes).
the programm should work permanently.
I tried with a 1d-array but didn´t get a result. Could anyone help me?
Best regards
kasche
(3,054 Views)
Check this
May be its the same thing you want to achieve
http://forums.ni.com/ni/board/message?board.id=170&thread.id=312733
(3,052 Views)
Thanks for this link,
but i need to make a sum of all values in this array, too. And it should work permanent.
That makes me the greatest problems.
(3,030 Views)
Hi kasche,
in the math palette you will find a "sum" function - this will add all array elements...
What's your problem with "working permanently"? Can you attach an example to show the problem?
Message Edited by GerdW on 04-02-2008 03:17 PM
(3,027 Views)
Use the example in the posted link, then add another shift register for your sum of all elements. Dont add all the elements every time, add them to a running total when they come in. You will need to evaluate how big this number is going to get, however, and decide if you should use an I64 for your running total of all elements. Even this will overflow eventually.
So your code would look like that posted by GerdW in the above link, then add a shift register with a starting value of 0. Then add your input value to the value comming from this shift register and send the output to the shift register's output terminal. This creates your running total of all values. The code by GerdW provides your "last 18 elements" total in a very efficient manner, just change the 15 to an 18.
I have attached a sample bit of code to make it clear. I saved it in LV 8.0 so more people can open it.
CyberTazer
Software Systems Engineer
(3,018 Views)
It works!Smiley Very Happy
Thanks to all for the informations!
To GerdW. - yes it´s Germany
(3,001 Views)
