Get data inside a defined circle from a graph.
I have 3 column of data and I am plotting a surface plot where 1st and second column represents x and y coordinate of the graph and 3rd column is intensity. This works. I get a intensity plot (and also a 2d array).
What I want to do next is draw a circle of specified size and get the data (2d array) inside that circle. If 50% or more of any of the pixels are inside the circle, I would take it to be inside the circle.
Can I get some help how to do this?
(2,560 Views)
You're probably thinking of trying to do that in a graphical way, but maybe the easiest way is to plot the circle but use math to decide whether or not each point falls within the circle.
Bill
CLD
(Mid-Level minion.)
(2,553 Views)
the math should be straight forward, sqrt(dx^2+dy^2)>r remove point else it is in the circle where dx and dy are the distances of the point from the center x,y.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,539 Views)
