Get an error when open a TDMS file
When I open it with excel importer, the error information: TDS Exception in Initialize: Tds Error: TdsErrFileVersionTooNew(-2510). When I use TDMS file viewer VI in labview, get an error -2507, invalid group name and/or channel name.
I have worked for 3 days.
(3,547 Views)
The data acquired by a cRIO device, then transferred to PC use USB.
(3,535 Views)
Are you using LabVIEW to read this TDMS file?
Have you utilized the examples in the Example Finder? Help>> Find Examples..
Issues like this usually stem from a corrupt TDMS file or one that's too big, does this sound like something that could be the case with your setup?
Let me know. The only solution I've seen for this is a forum post for LabWindows CVI:
Cannot open tdms file
http://forums.ni.com/t5/Measurement-Studio-for-VC/cannot-open-tdms-file/m-p/2052194#M7669
Let me know what your environment is so we can better help.
David
(3,484 Views)
