Get an error when importing multiple NI MAX configuration file using LabVIEW
Dear Community,
Thanks for all of your support for years. I'm writing a new post for following issue.
I get errors when importing multiple configuration file through LabVIEW programmatically. A bizarre response that I've noticed in my application is that when I put the breakpoint at the end of the import function and iterate over one at time then it doesn't throw any error message. Don't know how that break point is helping with configuration load.
When I use a small VI, not the actual project, then I'm able load these multiple configuration in one shot. Please see the attached files for projects and errors. Any advise on this issue will be highly appreciated.
Jatin
(2,456 Views)
Hi ackatharotiya,
Can you try putting in a delay between loading these config files (maybe try a second or two and then try reducing)?
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(2,326 Views)
