Get an error in save.cpp at line 1477 during application build
The build failed running on a NT machine but worked on a 98 machine.
(2,897 Views)
This error is not listed on the web. What version of LabVIEW are you using? Can you build any executable? What happens if you try to build on the 98 machine again? Is the VI working properly on the NT box? Are you using special hardware or software?
Reinstalling LabVIEW on the NT box is a good troubleshooting step.
(2,897 Views)
I am running V6.1.
I can build other applications OK and can consistently build on the 98 box and not on the NT box.
Based on the other 1477 error listed on the forum, I tried ctrl-shift-run. This seems to have sorted out the problem. No errors came up but it now builds properly.
(2,897 Views)
Cool, I am glad to hear you found a solution.
(2,897 Views)
